06-25-2006 09:09 PM - edited 03-03-2019 01:07 PM
Hi all
I have one question, i have one router and which connected two different PC( PC1-10.1.1.1) and ( PC2- 192.1.1.1), i don't put default gateway on my pcs.
Question
1) Will PC1 & PC2 are communicate with each other ?
2) for this scenario , which technology called like ( proxy arp ,bridge/routing/irb)etc..
06-25-2006 09:30 PM
I believe both the IPs are on same router.(Either on 2 ports or one 1 port)
(1)No.
(2)If u want bridiging then why are u using a router and given 2 different IPs(10.1.1.1 will not ping to 192.1.1.1 without using a router)?
If this helps then pls rate and if any probs. ....simply revert back.
JD
06-25-2006 10:51 PM
If you have proxy arp enabled on the router interfaces and your PC OS stacks broadcast arp queries when no default gateway is configured then yes it will work.
