Routing to 2 networks from fast ethernet ports of an 857
Hi , I have had a 1720 for some years routing to 2 networks ( one lan 192.168.1.x , one DMZ 203.53.178.x) via 2 ethernet interfaces .
we got an 857 as part of an ADLS 2 upgrade but i don't know who to set up the routing on the fast ethernet ports.
is the above routing possible ?
it seems we are limited to one VLAN ?
Silver
Re: Routing to 2 networks from fast ethernet ports of an 857
can you enter the command :"no switchport" under one interface?
this command let the interface a L3 one, then y can give it an IP address.
No, it does not like the "no switchport" command for a fastethernet port
( C850 -ADVSECURITYK9-M) version 12.4(11)T2
Silver
i think you need to change software.
Q. How many 802.1q VLANs can be configured on the built-in 4-port switch (Fast Ethernet 0-3)?
A. A maximum of four VLANs are supported on the Cisco 870 Series with the plus feature set (Advanced IP Services/Advanced Enterprise Services). The Cisco 850 Series only supports one 802.1q VLAN.
thanks , but don't you mean change hardware to an 877 ?
I was afraid of that
Silver
yes i think so :-(
153
