Community Member
Routing Traffic
I am not able to make this work. All traffic from VLAN 75 should be routed to Internet via AP#5
Vlan 75 should not communicate with other vlans on the network. Vlan75 should be propogated on all connected user switch to define vlan on wired port. users on Vlan 75 should get IP from AP#5.
AP#5 is connected to 4506 on port fa 0/10
##Configuration on 4506
Vlan 10
interface vlan 10
ip address 192.168.1.0 255.255.255.0
vlan 11
interface vlan 11
ip address 192.168.2.0 255.255.255.0
vlan 12
interface vlan 12
ip address 10.10.10.1 255.255.254.0
vlan 13
interface vlan 13
ip address 10.10.20.1 255.255.254.0
define L2 vlan 75
Vlan 75
description Vlan75
interface fa 0/10
switchport mode access
switchport access vlan 75
router ospf 5
network 192.168.1.0 0.0.0.255
network 192.168.2.0 0.0.0.255
network 10.10.10.0 0.0.1.255
network 10.10.20.0 0.0.1.255
## configuration on 2960
interface fa 0/1
interface fa 0/2
interface giga 1/0
switchport mode trunk
When I created L3 for Vlan75 ; it can communicate with other vlans which I dont want.
Any help
Hall of Fame Super Silver
Re: Routing Traffic
Hello  Nasr,
if you don't want devices in broadcast domain vlan 75 to communicate with other vlans you simply don't need to configure the L3 object SVI Vlan75.
if you want on the switch to have an ip address to test if that AP#5 is working, you can take advantage of VRF lite concept:
ip vrf  Guest
rd 100:110
route-target both 100:110
interface vlan 75
ip vrf forwarding Guest
ip address dhcp
no shut
you can then check IP connectivity using
ping vrf Guest  destination address
the VRF provides total isolation from other SVI interfaces that are part of the Global routing table.
Hope to help
Giuseppe
Community Member
Re: Routing Traffic
IP reachability is working, thank you sir.
it is must to use VRF.
Re: Routing Traffic
Hello Nasr,
it can be done also with IP ACLs applied in the SVI, but the VRF is a more elegant solution and ensures isolation over time.
if using an ACL and this is modified by mistake communication with other vlans can be permitted.
if you use VRF to allow communication with global routing table a specific configuration is needed for this reason using a VRF is safer.
Hope to help
Giuseppe
Community Member
Re: Routing Traffic
Thanks I will start with VRF
For ACL is this only needed, i tested in lab but doesnt work.
interface Vlan75
description W_VLAN
ip address 192.168.212.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip access-list extended W-ACL
deny ip any 192.168.1.0 0.0.0.255
deny ip any 192.168.2.0 0.0.0.255
deny ip any 192.168.3.0 0.0.0.255
deny ip any 10.10.10.0 0.0.0.255
deny ip any 10.10.20.0 0.0.0.255
permit ip any any
interface vlan30
ip access-group W-ACL in
351
