Community Member
Routing two addresses to remote over tunnel and other address go public
I have two IP addresses that need to communicate to a remote external IP addresse over established lan to lan tunnel vpn tunnel. All other local machines would route to remote external Ip address over public connections. What is best way to accomplish? Thanks
1 ACCEPTED SOLUTION
Re: Routing two addresses to remote over tunnel and other addres
Tom,
I'm glad to hear it worked, and thank you for the rating. =)
John
HTH, John *** Please rate all useful posts ***
I would say a policy map would be the best way to go in this situation.
route-map TUNNEL permit 5
match ip address TWO-HOSTS
set ip next-hop
access-lists TWO-HOSTS
permit ip host 192.168.1.1 host 172.17.2.2
permit ip host 192.168.1.2 host 172.17.2.2
int fa4 (public address where crypto map is)
ip policy route-map TUNNEL
I don't know if this will work, but it could be a good start
HTH,
John
Community Member
Here is follow-up question:
What happens when 192.168.1.3 tries to connect to 172.17.2.2
Is it discarded or routed normally?
Lan segment is 192.168.1.0/24
192.168.1.1 is local router DG and ip address on int fa4
Firewall is 192.168.1.250
ip route 0.0.0.0 0.0.0.0 192.168.1.250
VPN Concentrator is 192.168.1.100
What would happen to traffic that doesn't match policy route map, would it discard or route normal.
Community Member
John,
Can you reply to this post one more time? Your post resolved my issue and I would like to give you credit.
Tom
Tom,
John
117
