Spotlight January 2018 Silver
Routing using 2 ISP question?
I have to connect to my network a group of users that don?t share the same domain. I have created a new vlan for those users (vlan 20). This users can access my printers and some servers so they need to form part of intervlan routing. but ARE NOT ALLOWED TO USE MY ISP
I would like that thoses users access the the internet via a router axess-tel connected to my switch.
How can I route my traffic of this unique vlan via this axess-tel?
Example
Interface Vlan 30
Ip address 30.30.30.1 255.255.255.0
Interface Vlan 10
Ip address 10.10.10.1 255.255.255.0
Interface vlan 20
IP address 20.20.20.1 255.255.255.0 --- This users should use the internet via the axess-tel that have ip address 20.20.20.150
IP route 0.0.0.0 0.0.0.0 167.175.xxx.xxx ? All users but those on vlan 20 must use this route to access the internet.
How can I do this
Lp
1 REPLY
Re: Routing using 2 ISP question?
You need to use PBR to do this.
Deny the routes for the server/printer access from the PBR access-list and route all other traffic towards the axess-tel
access-list 100 deny ip 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 100 deny ip 20.20.20.0 0.0.0.255 30.30.30.0 0.0.0.255
access-list 100 permit ip any any
route-map axtess-tel permit 10
match ip address 100
set ip next-hop 20.20.20.150
interface vlan 20
ip policy route-map axtess-tel
You might need to edit the access-list if some access in future is required between some new vlans
HTH, rate if it does
Narayan
91
