Webcast-Catalyst9k
Routing
Hi ALL:
I am doing natting on the firewall and for that using the outside interface of firewall.
Since have 2 ISP do i have to create logial interface on the firewall for 2 different ip?
I am not using any routing protocol only default route to ISP.
What is the best way to configure the firewall interface and router
Chao
Vishwa
1 REPLY
Re: Routing
Hi Vishwa,
The best way would have been with different Interface , but it all depend on number of inetrface you have. But i will suggest that you creat HSRP between the 2 ISP and then link the one interface to Firewall.
DAK
93
