Community Member
routing
Hi All;
extended ping between fa 0/0 and fa 0/1 doesn't reply. what command should I use?
thanks
Re: routing
Are you saying that the normal ping give response?
In extended ping, what is the interface u are choosing?
Try the command "ip routing" and then ping.
JD
Community Member
Re: routing
are both the port on the same router. if on the same router make sure both the interfaces are up and running.
please rate if helps
kamlesh
Community Member
Re: routing
Hi;
I tried "ip routing" but still I can't ping from fa0/0 to fa0/1.
Re: routing
Can U post the network structure?
Can U post the router config?
Also what u r doing?
JD
99
