Community Member
routing
how to configure reverse route in router?....help needed urgently
1 REPLY
Re: routing
Can you be a bit more elaborate on your requirement?
A reverse route is a route which the router uses to reach a source from where the traffic has originated.
It could be a normal static route or a dynamically learnt route.
HTH, rate if it does
Narayan
103
