RP selection in PIM-SPARCE-DENCE-MODE
hi,
When configuring PIM.Sp.DEN mode mor multicasting if more that two routers are configured as RP for the same group which becomes the final RP for that group?
Please share any experience.
Any link on cisco.com.
Thanks in advance.
Subodh
2 ACCEPTED SOLUTIONS
Re: RP selection in PIM-SPARCE-DENCE-MODE
Subodh,
I suppose you are referring to auto-rp. The RP with the highest IP address will be elected the RP.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi Subodh,
If you use Auto-RP, mapping agent will choose the RP with the highest IP address
If you use PIM-BSR, each multicast router will run an Hash algorithm to choose the RP. At the end each router choose the same RP for a group or group range.
If you use Anycast RP, each multicast router chooses its closest RP from an IGP metric perspective. RP's exchange their sources via MSDP.
More info:
http://www.cisco.com/en/US/docs/ios/solutions_docs/ip_multicast/White_papers/rps.html
Laurent.
Subodh,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Hi Subodh,
More info:
Laurent.
158
