02-26-2007 11:11 AM - edited 03-03-2019 03:56 PM
I am setting up the first agent for my RSVP configuration, and when doing a sh sccp i get this. Showing I failed to register with CCM. I am running CM5.1 using IOS c2800nm-spservicesk9-mz.124-11.T1.bin on a 2811 gateway.I have a MTP on CM called "MTPEast2". Any ideas why it fails to register?
Thanks Dan
East-2811-1#sh sccp
SCCP Admin State: UP
Gateway IP Address: 10.1.130.2, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.130.11, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 1
Call Manager: 10.1.130.10, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 2
Call Manager: 10.1.140.10, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 3
Software MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Active Call Manager: 10.1.130.11, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 20
Reported Max Streams: 200, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: pass-thru, Maximum Packetization Period: N/A
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period
: 30
RSVP : ENABLED
03-02-2007 11:42 AM
add the following cmds:
sccp
auto-config application sccp
server ip-address
exit
auto-config
for more info see:
03-02-2007 01:30 PM
The auto-config command does not work in the 2811 router.
04-01-2008 10:27 AM
Your attachment expired so I am just guessing here... The Cisco's brief help document for RSVP agent says you must add 'version 5.1' to the 'sccp ccm' command. It also says you must use IOS version 12.4(4)T or greater.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/int_rsvp.html
