Community Member
RSVP over unnumbered links, ISIS network
I am running an unnumbered core with ISIS, ldp is running fine, if i build a TE tunnel it will not establish, i get " Last Error: RSVP:: Could not add RSVP Path: Operation failed: internal error "
if i give my interfaces real addresses then the tunnels establish ok.
is this a limitation of RSVP, or is there a way to run unnumbered links in the core, and still do TE ?
I can't see anything that says it can't be done !
many thanks, Will
1 ACCEPTED SOLUTION
Re: RSVP over unnumbered links, ISIS network
William,
RSVP TE on ununmbered interfaces is not supported by IOS.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Silver
For the configuration for the RSVP follow the URL which will help you :
http://www.cisco.com/en/US/customer/docs/ios/12_1/qos/configuration/guide/qcdrsvp.html
Community Member
cool, i'm reading through thatm but, i still don't see any reference to unnumbered interfaces... are these allowed ?
William,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
240
