Webcast-Catalyst9k
enc
RTR or IP SLA PROCESS NUMBER
Let say I have two IP SLA requester and one IP SLA RESPONDER. Do I have to use different process number at the requesters, in order not to mess up at the RESPONDER - or is the RESPONDER able to handle request from two different routers with the same command e.g. "ip sla monitor 146".
1 REPLY
Purple
Re: RTR or IP SLA PROCESS NUMBER
The IP SLA operation number is a locally significant identifier only. As a result, you can use whatever number you want, and you can use the same number at all requestors, without causing any issues at the responder.
Hope that helps - pls rate the post if it does.
Paresh
293
