Community Member
Saturate a link.
Good day,
I have a p2p wireless link, the manufacturer put the theorical bandwith to 48Mbps. I want to saturate the link, and mesure exactly the real bandwith; i try it with ftp expert but i can't sature with it. Some body has a method of saturation ?
Any suggest will be appreciated.
regards.
Bronze
Re: Saturate a link.
Multiple two way transfers both ways would definitely push the link to its maximum capacity. One way transfers are not an ideal way of measuring the throughput because of the way TCP/IP works.
Start 2 ftp transfers one way and do the same on the other end.
In addition you could also try ttcp to achieve similar results, check out this link
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094694.shtml
Arvind
Purple
Howdy,
A great way of doing this is to use a tool such as IPERF which is capable of generating UDP streams, so that you don't run into the problem on TCP back-off etc.
Hope that helps - pls rate the post if it does.
Paresh
Community Member
i try the software TTCPW but, i have error.And my router can'nt run ttcp sender.
D:\SOFT\LINK BANDWITH TEST\TTCPW>ping renoir.csc.ncsu.edu
Envoi d'une requête 'ping' sur renoir.csc.ncsu.edu [152.14.53.12] avec 32 octets
de données :
Réponse de 152.14.53.12 : octets=32 temps=199 ms TTL=238
Réponse de 152.14.53.12 : octets=32 temps=251 ms TTL=238
Réponse de 152.14.53.12 : octets=32 temps=200 ms TTL=238
Statistiques Ping pour 152.14.53.12:
Paquets : envoyés = 4, reçus = 4, perdus = 0 (perte 0%),
Durée approximative des boucles en millisecondes :
Minimum = 199ms, Maximum = 251ms, Moyenne = 212ms
D:\SOFT\LINK BANDWITH TEST\TTCPW>ttcpw -t -s renoir.csc.ncsu.edu
ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=5001 tcp -> renoir.csc.ncs
u.edu
ttcp-t: socket
ttcp-t: error=10061
Good day Howdy,
do you have a tool IPERF for udp data tranfer ??
Regards.
Purple
You can get iperf for free from here:
http://dast.nlanr.net/Projects/Iperf/
Paresh
Community Member
i 'll send you a feedback at the end.
Regards.
Purple
No probs... just remember to use the '-u' option to get iperf to generate a UDP stream...
Paresh
Community Member
There is a little Windows utility called QCheck, originally written by NetIQ. You can download it from :
http://www.ixiacom.com/products/qcheck/
It provides a nice simple bandwidth measurement between two machines (latency as well). From my experience it seems fairly accurate. We've used it on everything from 100Mbps switched connections to DSL VPN connections.
Dave
Community Member
Thank, iperf is a good tools, i obtain 17.5Mbps on my p2p link.
I rate your post .
Thank you very much.
233
