School boy error please help Switch 2960 series
                   I have a school boy error attach is a screen dump , can some one please help , first year at Uni studing CCNA , i think its Discovery
I want my banner to be save so I don't have to type it each time , upon  global exec mode I type the following switch(config)#  banner incoming d  type your message here d  press return and the exit
this take me to privilege exec mode  i type switch# copy running-config startup-config
I get error please see the picture. any input would be great thanks
From the screenshot, it seems like you're trying to add another file to nvram and it's failing for that. When it shows you [startup-config] that means that it's going to write to that name by default. If you change the name, you're telling the switch that you want to write to a different file that's not the default. In this case, you can simply hit enter and you should be able to save the config. Alternatively, you can type "write" and hit enter instead of "copy running-config startup-config".
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
VIP Purple
HI Waheed,
If you type
99XCI001#copy running-config startup-config
Destination filename [startup-config]? con(Dont write this word...just enter from computer)
%Error copying nvram:con (Invalid argument)
99XCI001#
Just do enter :
Building configuration...
[OK]
99XCI001#
it will save ur running config to startup.
Reagrds
please rate helpful post.
262
