Webcast-Catalyst9k
SDM login
What are the login for SDM? Why does it need 2 level login?
I recently enabled a ssh access to a local machine. Which means there is a nat to forward port 22 to an internal pc and acl enable port 22 for dialer interface.
After that, when I tried to log into sdm, i was asked to provide ssh user/pass. I tried to use the same one, but failed.
But I still can telnet into the router. And there is no nat translation happening when I tried to login through sdm.
Can anybody explain this to me?
1 REPLY
Re: SDM login
Hi yaya
Try the line below in global config.
"ip http authentication local"
159
