11-23-2005 06:55 AM - edited 03-03-2019 11:03 AM
Hi all
Has anyone managed to get 2 channels out of 1 port on these cards ? The configuration guides only show 1 channel per port. Is this a limittation or teh example was meant to be simplified ?
Thanks in advance
Sam
11-23-2005 07:42 AM
As per the data sheet available it can support two or more channel groups but with that option selected you can have only one port supported in each slot..
do refer the link attached and also the abstract from the same...
"The VWICs also support a channelized capability where the T1 or E1 service can be flexibly split into two or more fractional channel groups. Thus a single physical port can provide connection to multiple sites. (Note: when choosing this mode only a single port can be supported in each WIC slot.)"
http://www.cisco.com/en/US/products/hw/modules/ps3115/products_data_sheet09186a0080091b9c.html
regds
11-23-2005 07:56 AM
Thanks for the reply!
If I understand it correctly, I could configure for example 4 @ 512K on a single port but only that on e port. The second port will be useless.
Ideally I would have loved to test this config myself before buying the cards.
Thanks again !
Sam
