securing cisco 2621XM
Hi, i am having problems with my pix 501 which i have taken for checks. In the interim, i am using a 2621XM router. Any helps on configurations for securing this router (almost like the pix). e.g blocking all traffic from outside and allowing all from inside. Can i configure VPN on this router? (cant find any "Crypto" or "VPN" commands.
D.
Silver
Re: securing cisco 2621XM
VPN and other security commands are possible with the router however you must have the correct IOS feature set to support them. If there are no commands such as ip inspect or crypto ipsec then i would say you probably do not have this feature set.
Your could configure access-lists to limit traffic while you wait for PIX to be replaced.
Good luck
Steve
Gold
just a little bit add-on.
providing the running ios doesn't support cbac or vpn, you can still configure tcp intercept in order to prevent dos attacks. and of course, acl is a must.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7c4.html
92
