Webcast-Catalyst9k
Serial HWIC for the Cisco 1861 router
I am planning to replace an old 7500 router with a smaller one.
The question I have is that the 7500 has a 4 port serial g703 unbalanced card (PA-4E1G/75 15-pin with D-shell (DB-15) receptacles on the port adapters and which operate in full-duplex mode at the E1 speed of 2.048-Mbps) and I am not sure what HWIC will do the same job for the Cisco 1861 router. Does anybody know?
Thanks in advance.
Everyone's tags (2)
Hall of Fame Super Gold
Re: Serial HWIC for the Cisco 1861 router
Can you configure the other side of the circuit for framed 30 or 31 channels ? That would allow you use even a vwic 1st generation, non capable of unframed mode.
Thank you for your comment Paolo, and apologies for the late reply. I was away for two weeks and I am just catching up with things.
To answer your question: No I can't do that. The circuit is E1 and the router I want to replace is a 7500 with a PA-4E1G703/G704 75 omh unbalanced. This type of interface uses the 15 pin-D shell at the router end, and two BNC connectros with coax at the other end. The cable used is CAB-E1-BNC= as shwon below.
My question is, what interface of the Cisco 1861 router can I use to connect this E1 circuit and/or what changes do I need to make to the circuit presentation to be able to use this router. The circuit is currently presented with two BNC female connectors
Thank you.
Arturo
407
