Webcast-Catalyst9k
Serial interface E1 - BW 1544 Kbit
We have a E1 installed and when i issue the sh int command i get 2BW 1544 Kbit" rather than 2048. Is the line speed picked up by the telco kit, how do i get it back up to 2 mb?
thanks
Re: Serial interface E1 - BW 1544 Kbit
hi
Thats the default interface bandwidth comes out with the interface.
You can change that to 2048Kbps manually thats nowhere related to the line speed or picked from telco..
regds
so are you saying that although the "show int s0/0" says 1544 i am actually getting 2048?
The bandwidth command will only affect upper protocols like EIGRP right so that will make no difference if i add it to my config?
hey i missed to mention how u can change up the same..
Router(config)# interface serial 0
Router(config-if)# bandwidth 2048
yes you are rite in pointing out that bandwidth specified under the interface is effective only when u run some routing protocols or having any CBWFQ related policies defined in the form of Policy map and binded under the interface..
regds
thanks, but i am still trying to find out if i have an issue or not. am i getting 2mb or only 1.5 from the telco?
hi you dont have any issues in getting 2Mbps from your telco provided they have allowed/configured the same at their end :-).
regds
cool,
thanks for the help...
687
