Serial interface help
elovelace256
How do I get this to work on a 2801 router.
Apparently I am doing something wrong.
interface Serial0/0/0:0.757 point-to-point
ip address 216.68.4.10 255.255.255.0
ip ospf message-digest-key 1 md5 5T33LP1P3
frame-relay interface-dlci 757
Thanks!!!
10 Replies 10
bjw
Level 4
Level 4
Can you provide the whole config? Is encapsulation frame-relay defined on the parent interface s0/0/0?
Bill
Bill here is the rest of the config
Current configuration : 3863 bytes
version 12.4
hostname SPS_T1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-3709427094
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3709427094
revocation-check none
rsakeypair TP-self-signed-3709427094
crypto pki certificate chain TP-self-signed-3709427094
certificate self-signed 01
3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33373039 34323730 3934301E 170D3037 30333031 32313039
34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37303934
32373039 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A329 405B54CE 365F754A 96A2F943 68401517 BF640B5D 575D7BD7 E0B4BA4A
4D3737F6 8FDFD2A2 EAF6A23C 9F424C04 F5B089A8 294A1113 AF356539 A20FCEBF
ABA84994 56AC18E7 37342747 10E20BB4 AAF742C1 8AF95D37 DF657AF9 56D1BAA0
C42E75A1 28BD05D8 D7B13B82 CA73D290 266ABCC0 A1BA8BB5 97FDFFA9 00525FEB
0A0F0203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
551D1104 19301782 15535053 5F54312E 796F7572 646F6D61 696E2E63 6F6D301F
0603551D 23041830 16801490 4CDE7B52 BFA0FB01 3EFECED3 34B805A4 D4806430
1D060355 1D0E0416 0414904C DE7B52BF A0FB013E FECED334 B805A4D4 8064300D
06092A86 4886F70D 01010405 00038181 0078C88B A2485871 53DC9CC3 57069AAC
D93F5D14 791FE09A A88BFBE6 29D3DCD9 788CBA69 FA6ADB50 EDDCB90F D95CAE03
45265487 8C2DC18D 9CDB72B9 31386011 07CE7FA2 EFDAF33E 2F90FD07 A0A2DE8F
120D66FB 2DA8360D 069A08DC C0965CF3 92A41A4D 53233A37 61FF8CE7 320AD8CA
A1E3A609 A6B0862C 4C8EB4F9 14CCE764 30
quit
username admin privilege 15 secret 5 $1$TlYy$kZkDi.U8Ph1RWvNkKXXfV0
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 10.79.113.199 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description $ES_LAN$
ip address 10.10.10.10 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
ip classless
ip route 10.79.0.0 255.255.0.0 10.79.113.3
ip route 10.79.1.0 255.255.255.0 10.79.133.1
ip route 10.79.5.0 255.255.255.255 10.79.113.3
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.79.0.0 0.0.255.255
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
Eric
There seems to be a mismatch between your first post and this one. The first post was specifying:
but in this post there is not serial0/0/0 at all. If you are trying to configure a subinterface, then what we really need to see is the physical interface under which the subinterface will be.
Also I am not understanding clearly what is not working (is it the subinteface, the IP address, the OSPF authentication, or the PVC/DLCI). Perhaps you can clarify that.
Rick
Rick
It is actually serial 0/1/0 (sorry misprint) What is happining when I enter config mode and type interface Serial0/0/0:0.757 point-to-point
it gives me an error:
SPS_T1(config)#interface Serial0/1/0:0.757 point-to-point
% Invalid input detected at '^' marker.
The marker is the 0 right after the colon.
Does this help? I am urgently needing this configured.
Eric
I think that Bill was pointing you int the right direction in his post. Your configuration has not specified encapsulation so it is using the default encapsulation of HDLC and subinterfaces are not supported in HDLC. If you configure encapsulation frame-relay you should find that the subinterface is accepted then.
Rick
Rick
Rick,
I changed serial 0/1/0 to encapsulation ppp and entered the command
but the error is still coming up at 0 after the colon :0.757
Eric
Neither HDLC nor PPP support subinterfaces. The encapsulation that does support subinterfaces is frame-relay.
Rick
Rick
I changed to frame relay and the same problem exists.
Do I have to be under the interface serial 0/1/0 to create the sub interface?
In my mind I wouldn't think so
Eric
If you have entered encapsulation frame-relay under interface serial0/1/0 the subinterface should work. You do not explicitly need to enter interface serial0/1/0 before you enter interface serial0/1/0.757.
Perhaps you can do a cut and paste from your terminal session when you are doing the configuration, so that we can see what is going on.
Rick
Rick
Sweet that worked Rick thanks
