02-27-2006 12:57 PM - edited 03-03-2019 11:53 AM
6 input errors, 6 CRC, 1 frame, 0 overrun, 0 ignored, 0 abort
7346 packets output, 1637988 bytes, 0 underruns
0 output errors, 0 collisions, 181 interface resets, 0 restarts
8 carrier transitions. How do I tell if this is a faulty eternal CSU/DSU or a Telco problem? Thanks in advance.
02-27-2006 01:32 PM
There are a few ways to accomplish this. Here are two:
Plug a T1 loopback into the T1 port in question (this will interrupt connectivity) and send constant traffic to the IP address assigned to that port. See if the errors continue to increment.
Bridge the T1 through a T1 test set and see which direction you're getting the errors from (likely bursts of all ones pattern from one side).
Below is a good link on troubleshooting T1/E1 issues:
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800a758d.shtml
02-27-2006 05:48 PM
You can also work with Telco to provide loops from their network and you can test from the A and Z ends of the ckt (provided you own the routers at each end). This will help to isolate which side you're seeing a problem with. Also you should verify the timing configuration with what you have configured and what the Telco is providing (e.g. internal or line).
You can put the CSU/DSU into a local (DTE) loopback and test from the router to the loop as well. Also, as previously mentioned use a loopback plug to put a hard loop up and test to it.
Hope this helps.
James
