Serial interface - leased line connection
Dear all,
I have a leased line between 2 site A & B. Both i already pre-configure but when i test, i can't ping between the 2 interface.
What could be the problem. I saw that the B interfece is (looped), what does it mean? Both serial interface i already connected to the modem/NTU
Site A (klcc)
Serial0/1/0 is up, line protocol is down
  Hardware is GT96K Serial
  Description: Connect to OU Router
  Internet address is 172.16.3.1/30
  MTU 1500 bytes, BW 512 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input never, output 00:00:03, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     799 packets output, 19176 bytes, 0 underruns
     0 output errors, 0 collisions, 1727 interface resets
     0 unknown protocol drops
     53 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Site B (OU)
Serial0/0/0 is up, line protocol is up (looped)
  Hardware is WIC MBRD Serial
  Description: Connection to KLCC Router
  Internet address is 172.16.3.2/30
  Last input 00:00:00, output 00:00:00, output hang never
     15 packets input, 1664 bytes, 0 no buffer
     Received 15 broadcasts (0 IP multicasts)
     15 packets output, 1664 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 carrier transitions
A loop is generated towards site B.It is not from your Site A or Site B modem, because both end serial is up.Co-ordinate with your service provider regarding the loop.I think a loop is generated from service provider end only .Please reply after doing the troubleshooting.
guys,
help me out here. any idea
Hi Soumik,
i get the isp to com to check. i'll reply later
it seem that the isp already rectified the problem is at their end. tq so much
