hi,
serial communication is the one type of communication method...in serial commynication you can send data in two form ...SYNCHRONUS and ASYNCH...
normaly our interface is in sync mode...when ever you enter command physical layer async under the interface configuration mode then this interface will ready for the async communication...
i think it will clear you idea...
rate this post if it helps
regards
Devang
