serial port V35 on 2600 router
How to know the serial0 or 1 (to v35 modem)was good or not ? is there any tool (software) or hardwire jumper to simulate loop back ?
Hendramp
Balikpapan-Indonesia
Re: serial port V35 on 2600 router
We can set loopback on V.35 MODEM and issue
sh interface serial x/x....and
see interface comes up with interface and line protocol up.
Rajesh
I did put the loopback on modem side then Line is UP and Protocol is UP, then after 10secs the Protocol goes DOWN but Line is UP. I reconfigure the serial0 but it does not solve the problem.
Let say I have only one router spare and I can't simulate the line with spare modem, any other way to simulate loop back on serial router ? or maybe loopback V35 cable ?
HendraMP
You can connect serial 0 and serial 1 interface with V.35 cable ...but for that you should have female V.35 cable ..then u can make one v.35 cable by connecting male and female together...and other two ends goes to serial1 and serial 0.
HTH.
you can use a hardware called "Loop back V35". You put it on modem and then use "show interface serial 1". If your V35 port on modem is working, it will display like this :
Serial is up, line protocol is up (Looped)
  Hardware is PA-MC-8TE1 Plus
766
