Webcast-Catalyst9k
Serial with VWIC2-2MFT-T1/E1 CARD
Hi ! really appreciate if somebody has this solution/ever encountered this problem:-
Wan conncations point to point
I've one side cisco router with wic 2T serial card the others side is VWIC2-MFT-T1/EI ehich is second gen of e1/t1 card, i understand this card is not supporting (channel-group unframe) so i configured timeslot 1-31 to make full use of 2 mb line, but the line is refuse to up, i swapped with test router (witH wic2t) it's working fine which means the line is ok... any explainnation would be much appreciated...
Re: Serial with VWIC2-2MFT-T1/E1 CARD
Hi!
For this card: VWIC2-MFT-T1/E1 did you specified to use T1?
Or better can you paste here your configs from both sides?
Thanks!
Cheers,
Calin
Hi Calin, I think I solved the problem, it's due to the setting at the NT, this card support structed but the modem at the remote side is setting unstrusted, once change to structed the line up immediately...
Thanks man..
115
