Community Member
Setting EIGRP Hold Timer Longer Than GRE Recursive Routing Loop Timer
I'm tired of adjacency rediscovery because GRE downs/ups an interface to force EIGRP to discover routes again after EIGRP mistankenly accepts a route to a distance tunnel loopback via the tunnel. I want to increase the EIGRP hold timers to greater than that to stop GRE from forcing my network from converging so many times a day. How long does it take for GRE to shut down/up an interface? I will then increase the hold timer to greater than that interval.
1 ACCEPTED SOLUTION
Silver
Re: Setting EIGRP Hold Timer Longer Than GRE Recursive Routing L
Why don't you block tunnel destination whic it is learning from tunnel itself? You can use distribute-list or distance commands to stop learning destination routes in EIGRP.
Saju
Pls rate helpful posts
Silver
Saju
How about just not adding the network to EIGRP command?
So if the remote loopback IP is x.x.x.x and local is y.y.y.y
Why not just configure the local EIGRP without "y.y.y.y"?
455
