01-03-2007 09:40 PM - edited 03-03-2019 03:14 PM
Using WIC-1DSU-T1V2, is the MTU fixed or configurable? I cant find commands regarding this. Thanks, Mitchell
Solved! Go to Solution.
01-03-2007 10:38 PM
To set the maximum transmission unit (MTU) size of IP packets sent on an interface, use the ip mtu interface configuration command. To restore the default MTU size, use the no form of this command.
ip mtu bytes
no ip mtu
you can go into interface config mode under the interface whose MTU you want to configure and try above commands. If it allows you to configure, it means you can set MTU otherwise not.
hope it helps ... rate if it does ...
01-03-2007 10:38 PM
ip mtu bytes
no ip mtu
01-07-2007 08:57 PM
What is the difference of the MTU value under
"sh int fa 0/0" and "sh ip int fa0/0"?
Tx
Jaya
