Setting up 3945 boot system file
I am upgrading 3945 router. Little confused to set the boot system file.
Output from show version
System image file is "flash0:c3900e-universalk9-mz.SPA.153-1.T1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
R1(config)#boot system ?
  WORD       TFTP filename or URL
  flash      Boot from flash memory
  flash0     Boot from flash0
  flash1     Boot from flash1
  ftp        Boot from a server via ftp
  mop        Boot from a Decnet MOP server
  rcp        Boot from a server via rcp
  rom        Boot from rom
  tftp       Boot from a tftp server
  usbflash0  Boot from usbflash0
  usbflash1  Boot from usbflash1
R1#dir
Directory of flash0:/
    1  -rw-    93157620   Nov 4 2013 21:03:04 -05:00  c3900e-universalk9-mz.SPA.153-1.T1.bin
    2  -rw-        3064   Nov 4 2013 21:13:52 -05:00  cpconfig-39xx.cfg
    3  drw-           0   Nov 4 2013 21:14:22 -05:00  ccpexp
  239  -rw-        2464   Nov 4 2013 21:16:08 -05:00  home.shtml
  240  -rw-   100829316  Aug 15 2014 20:32:18 -04:00  c3900e-universalk9-mz.SPA.154-2.T1.bin
Which of the below command is right to set up boot variable?
R1(config)#boot system flash0:c3900e-universalk9-mz.SPA.154-2.T1.bin
Or
R1(config)#boot system flash0 ?
  WORD  flash0 system image filename
R1(config)#boot system flash 0 flash0:c3900e-universalk9-mz.SPA.154-2.T1.bin
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
2900/3900 ISR G2 has two CF
2900/3900 ISR G2 has two CF slots.  So for the sake of accuracy, I'd go for this:
config t
boot system flash flash0:c3900e-universalk9-mz.SPA.154-2.T1.bin
end
wr
config t
end
wr
Thanks for taking the time to
Thanks for taking the time to rate our posts.  :)
This discussion has been
This discussion has been reposted from Additional Communities to the WAN, Routing and Switching community.
Hi Leo,What will be the
Hi Leo,
What will be the difference If I don't use "flash" keyword before "flash0:c3900e-universalk9-mz.SPA.154-2.T1.bin "
Thanks/Regards
If you don't use the location
If you don't use the location, i. e.  "flash0:" or "flash1:", the router will not know where to boot and might go into ROMmon.
If you don't want to use the "location" then don't put the second CF card.
Router#conf tRouter(config)
Router#conf t
Router(config)#boot system flash c3900e-universalk9-mz.SPA.154-2.T1.bin
Router (config)# do wr
Router (config)#do reload
653
