Setting up B8ZS and ESF
Scott Payne
Let me start by saying I am very basic in networking. I have a point-to point set up but am receiving an yellow alarm. The telco company is telling me that the problem is one of the routers is set to B8ZS/unframed when it should be seet to B8ZS/ESF. So my question is how do I check to see how it is set? And how do I change it? I have seen a lot of information about Controllers T1 1/0 etc. But am not too clear on it. If someone could help me on this I would really appreciate it. I am learning more every day about networking. Thanks for your help ahead of time. U can also email me at spayne@travelfocus.com
Thanks again!
Richard Burts
Scott
Where that is and how to get to it are dependent on what kind of router you are using (also whether it is an external CSU/DSU). It would be a good starting place if you would post the output of show version.
You might also look in the config and find the place that specifies B8ZS. That would be the place to specify ESF. Or you could post the configuration of the router (masking sensitive details such as passwords, public addresses, etc).
Rick
Rick
Thanks for your reply. I am using a 1721 series router on both sides. This is the far side config. The prot that the point-to-point has been set up on is Serial 1.
TFDal-MPLS-1721#sh run
Building configuration...
Current configuration : 2479 bytes
! Last configuration change at 12:15:43 UTC Sat Ja
! NVRAM config last updated at 12:05:42 UTC Sat Ja
version 12.3
hostname TFDal-MPLS-1721
boot-start-marker
boot-end-marker
enable secret x.x.x.x
enable password x.x.x.x
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip name-server x.x.x.x
no ftp-server write-enable
username xxx privilege 15 password 0 xxx
username idco privilege 15 password 0 x.x.x.x.
class-map match-all class1
description VOIP Access List for traffic to/from
match access-group 190
policy-map policy1
class class1
set precedence 5
bandwidth percent 30
interface FastEthernet0
description TO LOCAL LAN
ip address x.x.x.x 255.255.255.0
speed auto
full-duplex
interface Serial0
description SBIS CKT 45.x.x.x.x
no ip address
encapsulation frame-relay IETF
service-module t1 timeslots 1-24
frame-relay lmi-type ansi
service-policy output policy1
interface Serial0.642 point-to-point
ip address x.x.x.x 255.255.255.252
frame-relay interface-dlci 718
interface Serial1
description T1 to IDC P-to-P for Phone System Cir
router rip
version 2
redistribute static
network 10.0.0.0
network 70.0.0.0
network 75.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route x.x.x.x 255.255.255.0 x.x.x.x
no ip http server
access-list 190 remark .
access-list 190 remark . QOS map for VOIP Traffic
access-list 190 permit ip host x.x.x.x any
access-list 190 permit ip any host x.x.x.x
line con 0
password x.x.x.x
login
line aux 0
transport input all
flowcontrol hardware
line vty 0 5
password x.x.x.x
login
Show Version
TFDal-MPLS-1721#sh ver
IOS (tm) C1700 Software (C1700-IPBASE-M), Version 12.3(13), RELEASE SOFTWARE (fc
2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 10-Feb-05 08:03 by ssearch
Image text-base: 0x8000816C, data-base: 0x80CD9FEC
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-IPBASE-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
TFDal-MPLS-1721 uptime is 1 week, 1 day, 19 hours, 59 minutes
System returned to ROM by reload at 22:19:29 UTC Thu Jan 11 2007
System restarted at 16:26:30 UTC Thu Jan 11 2007
System image file is "flash:c1700-ipbase-mz.123-13.bin"
cisco 1721 (MPC860P) processor (revision 0x500) with 55747K/9789K bytes of memor
y.
Processor board ID FOC093211PP (2061242032), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
WIC T1-DSU
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Scott
The additional information is quite helpful. I would suggest that you try this:
interface Serial1
service-module t1 framing esf
Give it a try and let us know how it works.
Rick
Rick
