Setting up basic configs for a 2651 router and 2 x 2950 switches
Villian123
I am looking for advice on the following:-
I have 1 x 2651 router and 2 x 2950 switches and I want to learn to configure them for my CCNA.
I want to set up vlans and inter vlan routing on these devices, can anyone advise me on this please.
Paul
Peter Paluch
Hello Paul,
You have not indicated how you want your devices to be interconnected, so let me just suggest an interconnection and a possible configuration to make all this run:
Sw1 (fa0/11) --- trunk --- (fa0/11) Sw2 (fa0/12) --- trunk --- (fa0/0) 2651
Configure Sw1 as follows:
hostname Sw1
no ip domain-lookup
spaning-tree mode rapid
spanning-tree portfast default
vtp domain CCNA
vtp mode server
interface FastEthernet0/11
switchport mode trunk
exit
vlan 11
name FirstVLAN
vlan 12
name SecondVLAN
vlan 999
name ManagementVLAN
interface Vlan1
shutdown
interface Vlan999
ip address 10.255.255.11 255.255.255.0
no shutdown
ip default-gateway 10.255.255.1
switchport mode access
switchport access vlan 11
interface FastEthernet0/2
switchport access vlan 12
end
Configure Sw2 as follows:
hostname Sw2
no ip domain-lookup
vtp domain CCNA
vtp mode client
interface FastEthernet0/12
spanning-tree portfast trunk
interface Vlan1
shutdown
interface Vlan999
ip address 10.255.255.12 255.255.255.0
no shutdown
end
Configure the router as follows:
hostname R2651
no ip domain-lookup
interface FastEthernet0/0
no shutdown
interface FastEthernet0/0.11
encapsulation dot1q 11
ip address 10.0.11.1 255.255.255.0
interface FastEthernet0/0.12
encapsulation dot1q 12
ip address 10.0.12.1 255.255.255.0
interface FastEthernet0/0.999
encapsulation dot1q 999
ip address 10.255.255.1 255.255.255.0
end
This will configure your switches into management VLAN 999, and create two other VLANs 11 and 12 with Fa0/1 being in VLAN 11 and Fa0/2 being in VLAN 12 on both switches. The router is configured with subinterfaces for all three VLANs.
It's a very quick configuration but it should work right out of the box. While I am not explaining the individual commands, you should be aware of their meaning on CCNA level - and of course, if you are unsure of anything here, feel welcome to ask further!
Best regards,
Peter
9 Replies 9
Peter Paluch
Hello Paul,
hostname Sw1
no ip domain-lookup
vtp domain CCNA
vtp mode server
exit
vlan 11
name FirstVLAN
vlan 12
name SecondVLAN
vlan 999
name ManagementVLAN
interface Vlan1
shutdown
interface Vlan999
no shutdown
end
hostname Sw2
no ip domain-lookup
vtp domain CCNA
vtp mode client
interface Vlan1
shutdown
interface Vlan999
no shutdown
end
hostname R2651
no ip domain-lookup
no shutdown
end
Best regards,
Peter
Thanks Peter
It's given me a lot to think about.....much appreciated......
Paul
Peter
Ive configured the switches (apart from altering the IP scheme) and am having problems with SW2, below are the details I'm seeing.......it seems to start from the spanning tree command & vtp.
Thanks for your help
Paul
Password:
SW2>en
Password:
SW2#config t
Enter configuration commands, one per line.  End with CNTL/Z.
SW2(config)#hostname SW2
SW2(config)#no ip domain-lookup
SW2(config)#spanning-tree mode rapid
% Invalid input detected at '^' marker.
SW2(config)#spanning-tree portfast default
SW2(config)#vtp domain CCNA
SW2(config)#vtp mode client
SW2(config)#interface FastEthernet0/11
SW2(config-if)# switchport mode trunk
SW2(config-if)#interface FastEthernet0/12
SW2(config-if)# spanning-tree portfast trunk
SW2(config-if)#interface Vlan1
SW2(config-if)# shutdown
SW2(config-if)#interface Vlan999
SW2(config-subif)# ip address 192.255.255.12 255.255.255.0
SW2(config-subif)# no shutdown
SW2(config-subif)#ip default-gateway 192.255.255.1
SW2(config-if)# switchport mode access
SW2(config-if)# switchport access vlan 11
SW2(config-if)#interface FastEthernet0/2
SW2(config-if)# switchport access vlan 12
SW2(config-if)#end
00:31:07: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to up
00:31:07: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to down
00:31:07: %LINK-3-UPDOWN: Interface FastEthernet0/12, changed state to up
00:31:07: %LINK-3-UPDOWN: Interface FastEthernet0/12, changed state to down
Hi Paul,
Can you please post the show version output from your SW2? Also, did the suggested configuration work on SW1 - was it accepted without errors?
Best regards,
Peter
Peter
Sw1 went fine with no errors.  Below is Sw2 show version output.
Paul
Switch 2 - show version output
User Access Verification
Password:
SW2>en
Password:
Password:
SW2#sh ver
IOS (tm) C2950 Software (C2950-C3H2S-M), Version 12.0(5.3)WC(1), MAINTENANCE INT        ERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 30-Apr-01 07:56 by devgoyal
Image text-base: 0x80010000, data-base: 0x8031A000
ROM: Bootstrap program is CALHOUN boot loader
SW2 uptime is 1 minute
System image file is "flash:c2950-c3h2s-mz.120-5.3.WC.1.bin"
cisco WS-C2950-24 (RC32300) processor (revision C0) with 22260K bytes of memory.
Processor board ID FOC0612W2B2
Last reset from system-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:09:43:D9:51:40
Motherboard assembly number: 73-5781-09
Power supply part number: 34-0965-01
Motherboard serial number: FOC06120G3V
Power supply serial number: DAB06121ECZ
Model revision number: C0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FOC0612W2B2
Configuration register is 0xF
SW2#
Hi Paul,
Thank you. The IOS on your SW2 is very old. You should probably replace it with the IOS running on your SW1, assuming that SW1 is of the same type as SW2. Will you be able to do it?
Best regards,
Peter
Peter
I thought it would be something like this.
Can I take the IOS from Sw1 and copy it to my laptop using tftp and then copy it accross to Sw2 ?
If this is possible, can I trouble you for some advice on this?
Paul
Paul,
You are welcome.
With a little bit of luck, we can configure SW1 to be a TFTP server itself, and offer its IOS to SW2. This way, you can download it directly from SW1 to SW2 without an intermediate TFTP server on your PC.
Interconnect both SW1 and SW2 with a crossover cable (Fa0/1), and configure them as follows:
SW1: Before configuring, enter the dir flash: command and note or copy to the clipboard the exact name of the IOS image in the FLASH.
hostname SW1
interface Vlan1
ip address 10.0.0.1 255.255.255.0
no shutdown
tftp-server flash:exact_name_of_IOS_image_in_FLASH
SW2:
hostname SW2
interface Vlan1
ip address 10.0.0.2 255.255.255.0
no shutdown
After configuring them this way, try pinging SW1 (10.0.0.1) from SW2. If that is successful, you will need to erase your current FLASH (I do not believe it is large enough to hold both IOSes) and copy the new IOS from SW1:
erase flash:
copy tftp://10.0.0.1/exact_name_of_IOS_image_in_FLASH flash:
This should start the procedure of transferring the IOS image from SW1 to SW2. After this is completed, restart SW2.
If anything goes wrong after you've erased the FLASH on SW2, do not panic. If possible, do not unplug the switch and do not reload it. Even if you do, we can easily salvage it, just the operation will need to be performed through the COM port, and that will take much longer than through Ethernet.
Let me know.
Best regards,
Peter
Paul,
Contact me at Peter.Paluch@fri.uniza.sk - the instructions to do a switch recovery are better explained over e-mail.
Best regards,
Peter
