settings for etherchannel
prashantrecon
Two isp for point to point link etherchannel concept
Isp 1 has auto neigiotation seetings
Isp2 2 has full duplex and speed 100
Does this creates problem for etherchannel
Thus both isp should have same seetings such as auto
I am geeting suspended error for etherchannel
8 Replies 8
Giuseppe Larosa
Hello Prashant,
already answered in another thread in LAN forum
yes it can cause problems as the speed and duplex settings are not identical even if both are 100 full one is the result of negotiation and one is manually set
You have to make both links identical also for speed and duplex and you have to contact ISP tech stuff to see how to to do it.
Hope to help
Giuseppe
Please find attachement of my config
Hi  Giuseppe
I am successfuly in bundling the link.But not able to obtain redudancy particular with one link only.
As I told you  there are two links eg isp1 and isp2.
If isp1 goes down there is no problem.
If isp2 goes down than entire concetivity will be lost ?
Please suggest.
Please suggest
Hello Prashant,
may you post the following:
a) with both link operational
show etherchannel N  detail
from both switches where N is the port channel number
b) with only one link operational  (ISP2 down)
You have to check if both links are operational on both sides according to switches
Hope to help
Giuseppe
interface GigabitEthernet1/32
no ip address
channel-group 77 mode on
end
nihilent01#show running-config int gi2/32
Building configuration...
Current configuration : 112 bytes
interface GigabitEthernet2/32
description "p2p airtel 10 Mbps"
no ip address
end
interface Port-channel77
ip address 192.168.2.52 255.255.255.0
77     Po77(RU)         -        Gi1/32(P)      Gi2/32(P)
on site 2
47     Po47(RU)         -        Gi1/0/39(P) Gi2/0/39(P)
interface GigabitEthernet1/0/39
no switchport
no ip address
channel-group 47 mode on
end
interface GigabitEthernet2/0/39
description " p2p airtel 10mbps"
no switchport
no ip address
end
interface Port-channel47
no switchport
ip address 192.168.2.51 255.255.255.0
Port-channel: Po77
Age of the Port-channel   = 16d:17h:50m:40s
Logical slot/port   = 14/26          Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Passive port list   = Gi1/32 Gi2/32
Port state          = Port-channel L3-Ag Ag-Inuse
Protocol            =    -
Fast-switchover     = disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     55     Gi1/32   On    4
  1     AA     Gi2/32   On    4
Time since last port bundled:    0d:14h:35m:40s    Gi2/32
Time since last port Un-bundled: 0d:14h:36m:07s    Gi2/32
Port-channel: Po47
Age of the Port-channel   = 1d:00h:07m:28s
Logical slot/port   = 10/47          Number of ports = 2
Passive port list   = Gi1/0/39 Gi2/0/39
Protocol            =    -
Port security       = Disabled
  0     00     Gi1/0/39 On                 0
  0     00     Gi2/0/39 On                 0
Time since last port bundled:    0d:23h:21m:24s    Gi2/0/39
Time since last port Un-bundled: 0d:23h:25m:34s    Gi1/0/39
Hi Giuseppe ,
Today I observed a strange behaviour.
On site when 1shut down the interface gi1/32  than from site 1 i was not able to ping site2 end servers(from site 2 i didnot shutdown gi1/0/32)
But when from site 2 i was able to ping site 1 servers.strange
Than i decided to shutdown the interface gi1/32 from site 1 and gi1/0/39 from site 2 than both side were able to access the servers.And also the data was getting replicated through others isp link.Failover is taking place.
Than question
As I have two links with 20 Mbps each  so tottaly 40 MBPs.
Is it possible to load balance 20mbps data on each link.As this is L3 etherchannel how can i achieve this.
Hello Prashant,
without a control protocol like LACP you can face issues like the one you have described.
I know that you have already tried to use LACP with no success. I would suggest you to try again.
Load balancing will be based on  IP source address EXOR IP destination address
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_58_se/configuration/guide/swethchl.html#wp1275503
Hope to help
Giuseppe
Thanks a lot for your guidance.
Not able to bundle using lacp.
can u explain load statement.  On one side it indicates load as 55 and AA.
And one side it indicate 00
  0     55     Gi1/32   On    4
  1     AA     Gi2/32   On    4
I
  0     00     Gi1/0/39 On                 0
  0     00     Gi2/0/39 On                 0
