07-25-2007 12:53 AM - edited 03-03-2019 06:01 PM
We have a vrf-lite routing instance setup on a 3750 network which runs fine. However we can't work out how to do a sh arp table for the vrf. A sh arp in the global routing table works fine.
But the command doesn't seem to exist for the vrf. We are running 12.2(25)SEE3.
Have tried the following
sh arp vrf name but comes back with
#sh arp vrf education ?
% Unrecognized command
Any ideas why this occurs, is it not supported in the IOS version we are running?
Cheers
07-25-2007 12:10 PM
Yes, that IOS not supporting that command.
you can see all are available commands in 12.2(25)SEE
Click on S... available show commands are there.
Dharmesh Purohit
07-25-2007 11:10 PM
Thanks for that, do you know if the command is supported in later releases?
