sh dsl atm 0 - train speed/sync
When you look at the output of the sh dsl atm 0 command output you see a line referencing speed.  In the below example, would it mean that the line is synched at 3360 downstream and 832 upstream?
sh dsl int ATM0
ATM0
Alcatel 20150 chipset information
                                     ATU-R (DS)                      ATU-C (US)
Modem Status:             Showtime (DMTDSL_SHOWTIME)
DSL Mode:                                ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:                 0x01                            0x1
Vendor ID:                     'ALCB'                          'BDCM'
Vendor Specific:           0x0000                          0x544D
Vendor Country:             0x00                            0xB5
Capacity Used:              38%                             89%
Noise Margin:                19.0 dB                         10.0 dB
Output Power:                5.5 dBm                        12.0 dBm
Attenuation:                  27.5 dB                         13.0 dB
Defect Status:               None                            None
Last Fail Code:                          None
Selftest Result:             0x00
Subfunction:                  0x15
Interrupts:                     2651 (0 spurious)
PHY Access Err:           0
Activations:                   1
LED Status:                              ON
LED On Time:               100
LED Off Time:                            100
Init FW:                          embedded
Operation FW:                embedded
SW Version:                  3.8131
FW Version:                              0x1A04
                                     Interleave             Fast    Interleave              Fast
Speed (kbps):               3360                   0           832                         0
Cells:                            52195102                0           828405339            0
Reed-Solomon EC:         38                    0             0                   0
CRC Errors:                   0                      0             0                    0
Header Errors:               0                      0             0                     0
Bit Errors:                     0                      0
BER Valid sec:              0                       0
BER Invalid sec:             0                     0
LOM Monitoring : Disabled
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 4 6 8 A A A B C C
10: B B B B B B C C B A A A 9 9 0 0
20: 0 0 0 0 0 0 0 0 2 2 2 2 2 3 3 4
30: 4 4 4 4 5 5 5 5 5 5 6 6 6 6 2 6
40: 6 6 6 6 6 6 6 6 5 5 5 5 5 5 5 5
50: 4 5 4 5 5 4 5 5 5 5 5 6 6 6 6 6
60: 6 6 6 6 6 6 6 6 7 7 7 7 7 7 7 7
70: 7 7 7 7 7 7 7 6 6 7 7 6 7 6 6 6
80: 6 6 6 6 6 6 6 6 5 5 6 5 5 5 5 5
90: 5 5 5 5 5 5 5 5 5 5 5 5 6 6 5 6
A0: 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6
B0: 6 6 6 6 6 6 6 6 6 6 6 6 6 5 6 5
C0: 5 5 5 5 5 5 5 5 5 5 5 5 5 4 5 5
D0: 5 5 5 5 5 5 5 5 5 4 4 4 4 4 4 4
E0: 4 4 4 4 4 3 3 3 3 3 2 2 2 2 2 2
F0: 2 2 2 2 2 2 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
Thank you.
1 REPLY
Hall of Fame Super Silver
Re: sh dsl atm 0 - train speed/sync
Hello Ikadlik,
yes your understanding is correct both downstream and upstream directions use interleaving that protect DSL signal from noises for example caused by PSTN service on the same line.
The noise margin provides you direct info about the line quality.
Hope to help
Giuseppe
1955
