Webcast-Catalyst9k
sh ip route command output
In the show ip route network_A command shows no subnet in routing table. But we could ping the ip address. How to check default route of router ? Does router shows default route when it didnt find particular route in routing table.
Thanx in advance
Subodh
Green
Re: sh ip route command output
The default route could show in two places:
As the "Gateway of Last Resort"
or
as S 0.0.0.0 0.0.0.0 {gateway address} in the routing table ("S" is a static route).
The default route can be entered two ways:
One with a "next-hop" gateway address or one with just an interface listed.
i.e.,
ip route 0.0.0.0 0.0.0.0 10.1.1.1 (10.1.1.1 would be the upstream router / gateway address)
or
ip route 0.0.0.0 0.0.0.0 s0/0
The difference between the two is how the routing protocol / router will adjust the routing table (if possible) when the normal egress interface goes down.
Good Luck
Scott
Bronze
when u see the show ip route command output
by seeing this below Line you can check whether default route is set or not.
Gateway of last resort not set
or
Gateway of last resort set using X.X.X.X
This is used when u dont have any route to a particular network in your routing table.
to set the gateway of last resort u can configure by using the default-network command or the static route
ip route 0.0.0.0 0.0.0.0 (outgoing interface / next-hop IP)
HTH,
Raj
462
