sh ip route eigrp
tel me about the difference between show ip route and show ip route eigrp command.
Re: sh ip route eigrp
show ip route shows all the routes currently in the forwarding table.
show ip route eigrp shows only those routes in the forwarding table that were derived from EIGRP.
You can put RIP, OSPF, etc in the parameter to select particular routing protocols. With OSPF and EIGRP, if you have multiple processes or ASs, then you can do it selectively per process too.
Kevin Dorrell
Luxembourg
Sh ip roue command shows
C 199.40.118.128/25 is directly connected, FastEthernet0/0
D 199.40.118.64/26 [90/4732416] via 199.40.117.6, 03:34:33, Multilink1
10.0.0.0/32 is subnetted, 1 subnets
and show ip route eigrp command shows
199.40.118.0/24 is variably subnetted, 2 subnets, 2 masks
D 199.40.118.64/26 [90/4732416] via 199.40.117.6, 03:35:31, Multilink1
Kindly tel me there is some thing wronge or not what is it means??
Hall of Fame Super Silver
adnan
Perhaps there is something in your environment or in your post that I am not understanding. But it seems to me that Kevin gave the correct explanation. In the first part of your question:
Sh ip route command shows
The show ip route shows a connected route and shows an EIGRP route. While in the second part:
the show ip route eigrp shows the eigrp route but does not show the connected route. I do not see anything wrong with this.
If there is something here that I am not understanding can you clarify for me?
Rick
232
