Webcast-Catalyst9k
Shapping first or CBWFQ ?
For the below conf , what takes place first ?
shapping--->>CBWFQ-->Policing
OR
Policing--->>CBWFQ-->>shapping
interface Serial0/0/0.1 point-to-point
ip address x.x.x.x 255.255.255.252
frame-relay interface-dlci 539<<--FRTS
class COS-OUT-S0/0/0.1
policy-map COS-OUT-S0/0/0.1
class DSCP-OUT-D1
bandwidth remaining percent 60
random-detect dscp-based
service-policy COS-OUT-D1-S0/0/0.1
policy-map COS-OUT-D1-S0/0/0.1
class DSCP-OUT-D1INP
police cir 1232000 bc 154000 be 154000
conform-action transmit
exceed-action set-dscp-transmit 28
Re: Shapping first or CBWFQ ?
neither of the two. your config would do cbwfq then police. there's no "shape" keyword command in your policy-map config.
John
No in fact we do have FRTS on the DLCI , I just did not want to add it so as not make the post too long , I only add "<<--FRTS" to the DLCI
map-class frame-relay COS-OUT-S0/0/0.1
frame-relay cir 1986560
frame-relay bc 40960
frame-relay be 0
frame-relay mincir 1986560
service-policy output COS-OUT-S0/0/0.1
134
