Community Member
shdsl
Hi All
I have been trying to make this board work , with the below configuration , but unsuccefully .
HWIC-4SHDSL , G.HS G.SHDSL , DSLSAR , ITU G.991.2 G.994.1
DSLAM Interoperability
Alcatel ASAM 7300 (12-port Conexant-based line card)
ECI HiFocus SAM 480 (16-port Infineon-based line card)
Lucent Stinger FS (48- and 72-port Conexant-based line cards)
Alcatel ASAM 7300 , SMLT-A , LDP7AA46.017
ECI HiFocus SAM 480 , STUC-16 , S3_8.10.10
Lucent Stinger FS , STGR-LIM-SL-72 , 9.7.3 (R3.0.2)
Lucent Stinger FS , STGR-LIM-SL-48 , 9.7.3 (R3.0.2)
controller SHDSL 0/1/0
termination cpe
dsl-group 0 pairs 0, 1
shdsl annex B
shdsl rate 4096
I found a document that says :
The 2-pair and 4-pair G.SHDSL HWICs supersede the existing G.SHDSL WAN Interface
Card (part number WIC-1SHDSL-V3), which is a WIC-based G.SHDSL solution.
The two new G.SHDSL HWICs provide higher performance and increased reach when
compared to the G.SHDSL WIC.
The working board has the following configuration :
WIC-1SHDSL-V3 , G.SHDSL , MPC ATMSAR, ITU G.991.2
Alcatel ASAM 7300 (12- and 24-Port Line Cards)
ECI HiFocus SAM 240 (16-Port Metalink-Based Line Cards)
Lucent Stinger FS (32- and 48-Port Line Cards)
controller DSL 0/3/0
mode atm
line-term cpe
line-mode 4-wire standard
dsl-mode shdsl symmetric annex B
ignore-error-duration 30
snr margin current disable
snr margin snext disable
line-rate 4096
Patrizio
206
