05-16-2018 12:30 PM - edited 03-05-2019 10:28 AM
Is anyone aware of a way that I can easily execute and gather the results of a 'show cdp neighbor' command on 100 switches?
Aaron
Solved! Go to Solution.
05-16-2018 01:07 PM
Kiwi CatTools is a program that can accomplish this. It has a learning curve of it's own though, but it's a very powerful tool that will continue to prove it's worth if you ask me.
05-16-2018 01:07 PM
05-16-2018 01:44 PM
Thanks, I had been looking for a cisco command that might accomplish this somehow because I thought cattools was going to give me a bunch of different files, but I found a way to dump it all into the same location. From start to finish it took only about 10 minutes.
05-16-2018 02:29 PM
Good to hear. I use Notepad++. You can import all files as workspace, then you can search that workspace as if it were a single file. There is also a combine plugin for Notepad++ where you can combine all files into one file. Either way, once you get the process down, you can do hundreds of devices in short time.
