Show Policy-map Interface
Hi, i have a problem with this show (show policy-map interface) for my cpe.
Router: 2901
Version IOS : c2900-universalk9-mz.SPA.151-4.M4.bin
this command not display information, i need check the % and packet drops for my wan interface.
Thxs
have u created any police map for interface
show interface stat
Jawad
Jawad
Make sure that you have the policy-map applied. It still has to be applied to the interface before it takes effect with "service-policy ".
You can see if it's applied with a "show run int s0/0 (or whatever interface it should be on)".
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
im sure the policy-map applied on interfce serial.
check this display..
KPMG_AGS#show ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         10.168.181.254  YES NVRAM  up                    up
GigabitEthernet0/1         192.168.1.1     YES NVRAM  down                  down
Serial0/0/0                unassigned      YES NVRAM  up                    up
Serial0/0/0.1              192.168.0.10    YES NVRAM  up                    up
KPMG_AGS#show polip
KPMG_AGS#show policy-map interface serial 0/0/0.1
SHOW RUN
class-map match-all AF41
match access-group 150
class-map match-all AF31
match access-group 100
class-map match-all voicep
match ip dscp ef
class-map match-all videoc
match ip dscp af41
class-map match-all datag1
match ip dscp af31
policy-map vpnmsv
class voicep
  priority percent 20
class datag1
  bandwidth percent 60
  random-detect dscp-based
  random-detect dscp 26 20 40 10
class class-default
  fair-queue
policy-map SETDSCP
class AF31
  set ip dscp af31
class AF41
  set ip dscp af41
interface GigabitEthernet0/0
ip address 10.168.181.254 255.255.255.0
ip directed-broadcast
duplex full
speed 100
service-policy input SETDSCP
interface GigabitEthernet0/1
duplex auto
speed auto
interface Serial0/0/0
description CONEXION HACIA VPN AXTEL
bandwidth 1024
no ip address
no ip redirects
encapsulation frame-relay
no ip route-cache
frame-relay class vpnmsv-frf1024
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
description ENLACE WAN AXTEL
bandwidth 1024
ip address 192.168.0.10 255.255.255.252
no ip route-cache
frame-relay interface-dlci 420
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.9
ip route 10.168.182.0 255.255.255.0 10.168.181.253
ip route 10.168.183.0 255.255.255.0 10.168.181.253
ip route 10.168.185.0 255.255.255.0 10.168.181.253
map-class frame-relay vpnmsv-frf1024
frame-relay cir 1024000
frame-relay mincir 1024000
service-policy output vpnmsv
Thxs for u help
Re: Show Policy-map Interface
Hi , Add the command frame-relay traffic-shaping under interface Serial0/0/0 then check the status .
593
