show privilege level of commands
can someone tell me what command will list out and show me what the default privilege command levels are. example: i want to know what level is set for traceroute command.
1 REPLY
Silver
Re: show privilege level of commands
The only privilege levels that have commands by default are 0, 1, and 15. You can see what is in level 0 by:
9-11-8-3725-118#en 0
9-11-8-3725-118>?
Exec commands:
call Voice call
disable Turn off privileged commands
enable Turn on privileged commands
exit Exit from the EXEC
help Description of the interactive help system
logout Exit from the EXEC
You see level 1 by typing disable:
9-11-8-3725-118>disable
9-11-8-3725-118>?
Exec commands:
access-enable Create a temporary Access-List entry
access-profile Apply user-profile to interface
call Voice call
clear Reset functions
connect Open a terminal connection
crypto Encryption related commands.
You'll see in that list that traceroute is a level 1 command. All commands not in this list are enable 15 commands.
266
