show running-config full
gglynn
Can someone please tell me what the point of the "full" option to the "show running-config" command is, and what sort of information (specifically) might be hidden if you don't use this option when issuing the command? The IOS documentation doesn't say.
mohammedmahmoud
Level 11
Level 11
The full keyword is the default option for the command, this makes, "show run" = "show run full", you can find below other details:
R6#show running-config ?
brief configuration without certificate data
class-map Show class-map information
full full configuration
interface Show interface configuration
linenum Display line numbers in output
map-class Show map class information
policy-map Show policy-map information
view View options
| Output modifiers
R6#show running-config in
R6#show running-config interface f0/0
Building configuration...
Current configuration : 122 bytes
interface FastEthernet0/0
ip address 192.168.1.6 255.255.255.0
duplex auto
speed auto
end
R6#
http://www.cisco.com/en/US/docs/ios/12_4/cfg_fund/command/reference/cfn_10h.html#wp1032363
BR,
Mohammed Mahmoud.
Are you sure? Because most IOS commands don't have default options.
Please always check the "Defaults" part in the DocCD for any command and you'll always find a default option, for example for this command i quote:
"The show running-config command without any arguments or keywords displays the entire contents of the running configuration file."
BR,
Mohammed Mahmoud.
