Simple BGP problem
CriscoSystems
Level 5
Level 5
This has to be one of those so-obvious-I-just-can't-see-it problem.
Router R1 (AS 790) is fully peered with R2 (AS 300). R1 has two network statements configured under its BGP process, 172.31.5.0 and 172.31.6.0. These networks are NOT showing up anywhere in R2's routing table (not just not showing up as BGP routes, just plain not showing up).
Since these are loopback networks; could it be there's an unacceptable "NEXT_HOP" attribute, or what? WHAT STUPID THING AM I GETTING WRONG HERE...
Here's the relevant parts of R1's config
interface Loopback5
ip address 172.31.5.1 255.255.255.0
interface Loopback6
ip address 172.31.6.1 255.255.255.0
router bgp 790
no synchronization
bgp log-neighbor-changes
network 172.31.5.0
network 172.31.6.0
neighbor 172.31.1.6 remote-as 300
no auto-summary
R1#sh ip bgp summ
BGP router identifier 222.1.1.1, local AS number 790
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
172.31.1.6 4 300 20 23 1 0 0 00:01:37 0
R1#
And relevant output from R2:
R2>sh ip bgp sum
BGP router identifier 222.1.5.1, local AS number 300
172.31.1.5 4 790 24 21 1 0 0 00:02:06 0
R2>sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
U - per-user static route, o - ODR
Gateway of last resort is not set
C 222.1.5.0/24 is directly connected, Loopback0
172.31.0.0/16 is variably subnetted, 4 subnets, 2 masks
C 172.31.1.4/30 is directly connected, Serial0
C 172.31.1.5/32 is directly connected, Serial0
C 172.31.1.8/30 is directly connected, Serial1
C 172.31.1.9/32 is directly connected, Serial1
R2>sh ip bgp
R2>
Thanks everyone. I look forward to being conked on the head with a saucepan and having something really obvious pointed out to me...
2 Accepted Solutions
justinmitchell
Level 4
Level 4
You need to use
network 172.31.5.0 mask 255.255.255.0
network 172.31.6.0 mask 255.255.255.0
Otherwise the routes will not show up.
Here is an example:
RTR1 without mask
Router#sh run | s bgp
router bgp 790
no synchronization
network 172.16.7.0
network 192.168.5.0
network 192.168.6.0
neighbor 192.168.1.2 remote-as 300
no auto-summary
Router#sh ip bgp | b Network
Network Next Hop Metric LocPrf Weight Path
*> 192.168.5.0 0.0.0.0 0 32768 i
*> 192.168.6.0 0.0.0.0 0 32768 i
With the mask command used
router bgp 790
no synchronization
network 172.16.7.0 mask 255.255.255.0
network 192.168.5.0
network 192.168.6.0
no auto-summary
*> 172.16.7.0/24 0.0.0.0 0 32768 i
RTR2 with mask used on RTR1
router bgp 300
no synchronization
neighbor 192.168.1.1 remote-as 790
no auto-summary
*> 172.16.7.0/24 192.168.1.1 0 0 790 i
*> 192.168.5.0 192.168.1.1 0 0 790 i
*> 192.168.6.0 192.168.1.1 0 0 790 i
(edited to correct IP addressing)
It's because you have this:
interface Loopback5
interface Loopback6
router bgp 790
no synchronization
network 172.31.5.0
network 172.31.6.0
Your loopbacks are class B address's.
Your routing table on R1 looks like this:
172.31.0.0/24 is subnetted, 2 subnets
C 172.31.6.0 is directly connected, Loopback6
C 172.31.5.0 is directly connected, Loopback5
With these two commands:
network 172.31.5.0
network 172.31.6.0
You are telling BGP to look for 172.31.0.0/16 which is not in the routing table. You have to tell BGP that you are using a /24 with:
15 Replies 15
viyuan700
Level 5
Level 5
with loopback address you need statements extra under router bgp 790
neighbor 2.2.2.2 (use ur address here) ebgp-multihop 2
neighbor 2.2.2.2 (use ur address here) update-source Loopback0
U need static routes if not using any IGP to reach those loopback address
see the link it has the things u r looking for
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f25.shtml#ebgploopconfigloop
I dont think ebgp-multihop is required, since bgp is already in established state.
Please check the bgp table of R1. R1 will share/advertise its bgp table to peers.
bgp will match EXACT route in routing table with network statement before advertising to its peers. try to specify mask along with network statements under bgp config.
bgp is in established state because of this statement
but loopback address are not counted as directly connected address so u have to use multihop statement
Giuseppe Larosa
Hello Stuey,
on R1 you have
neigh 172.31.1.6 remote-as 300
but on R2 IP routing table we see:
this would make me think you have inverted the ip addresses: it looks like 172.31.1.5 is on the R2 side of serial0
Hope to help
Giuseppe
justinmitchell
Level 4
Level 4
You need to use
Here is an example:
RTR1 without mask
router bgp 790
no synchronization
network 172.16.7.0
network 192.168.5.0
network 192.168.6.0
no auto-summary
router bgp 790
no synchronization
network 192.168.5.0
network 192.168.6.0
no auto-summary
router bgp 300
no synchronization
no auto-summary
Justin,
You're right. I was typing slowly in this thread. hehehe. 5-Point for ya!
Giuseppe: I thought that would be a peer-neighbor route advertised by a neighbor when using PPP. R1 should use 172.31.1.5. (grin)
Toshi
Hello Toshi,
you're right I wrote my post just after lunch without much thought.
it happens :)
Best Regards
Giuseppe
Giuseppe,
That's fine. To freshen you up. 5-Point for ya!
Toshi
Hello Justin,
that's absolutely correct.
Best Regards
Giuseppe
Indeed it works now with the mask parameter configured.
So why does IOS let us declare a network WITHOUT that parameter?
Not sure, but you can use other config options such as route-map and backdoor.
Well this is actually ridiculous now. I did a bit of research elsewhere on this site, and I found out that, with the network command configured WITHOUT a mask:
(from http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800945ff.shtml#topic1)
BGP introduces the classful network 75.0.0.0 in the BGP table if these conditions are met:
(1) The subnet in the routing table is 75.75.75.0 mask 255.255.255.0.
(2) You configure network 75.0.0.0 under the router bgp command.
(3) Auto-summary is enabled.
If these conditions are not all met, BGP does not install an entry in the BGP table unless there is an exact match in the IP routing table.
In the case of my original config, conditions 2 and 3 aren't met. But it says BGP won't install the route UNLESS there's an exact match in the IP table. There was! The loopbacks are directly connected and appear as such in the table!!
So what happened in this case?
interface Loopback5
interface Loopback6
router bgp 790
no synchronization
network 172.31.5.0
network 172.31.6.0
network 172.31.5.0
network 172.31.6.0
Ahhhh... even though auto-summary was disabled?
BGP will summarize a declared network to the classful address boundary if no "mask" parameter is declared; even IF auto-summary is disabled, is what you're saying?
