Simple QOS policy
sudermaniak
Hello !
I will desrcibe what I want to achieve as simple as possible.
I have cisco 800 series router.
This router is used for 2 things:
- internet connection
- ipsec vpn with remote cisco router
I'm looking for way to implemet on this router simple qos policy that do 2 things:
- enable higher bandwidth when connecting with specified adresses or hosts (for example: https://www.somesite.com)
- secure part of the bandwidth only for vpn tunnel: if the router is overloded by traffic to internet the portion of bandwidth for vpn will not be taken.
If You have any idea or sample conf.
that would be great. Please be detailed as much as possible.
Thank you.
s.jankowski
Level 4
Level 4
For Generic Routing Encapsulation (GRE) and IP in IP (IPIP) tunnel protocols, the command is applied on the tunnel interface, making QoS for VPNs a configuration option on a per-tunnel basis. Refer URL
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t2/ftqosvpn.htm#1019744
