Simple QoS problem
I try to configure QoS on my router. My configuration is very simple but I have a little problem I dont understand.
First step, I use an ACL to match packets and set DSCP to af41 :
access-list 101 permit tcp any any eq 3389
access-list 101 permit tcp any any eq 22
class-map match-all MarkRDP
match access-group 101
policy-map ClassificationQoS
class MarkRDP
  set ip dscp af41
interface GigabitEthernet0/1.101
encapsulation dot1Q 101
ip address 10.10.10.1 255.255.255.0
ip nat inside
service-policy input ClassificationQoS
My conf is correct, it's working :
#sh policy-map interface Gi0/1.101
  Service-policy input: ClassificationQoS
    Class-map: MarkRDP (match-all)
      10050 packets, 825827 bytes
      5 minute offered rate 4000 bps, drop rate 0 bps
      Match: access-group 101
      QoS Set
        dscp af41
          Packets marked 7021
    Class-map: class-default (match-any)
      56700 packets, 7301625 bytes
      5 minute offered rate 43000 bps, drop rate 0 bps
      Match: any
Second step, I try to regulate the output bandwidth for af41 on Dialer0 (my ADSL link) :
class-map match-all MatchRDP
match ip dscp af41
policy-map RegulationTrafic
class MatchRDP
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
  random-detect precedence 6 30 40 4
interface Dialer0
bandwidth 768
bandwidth receive 3776
ip nat outside
service-policy output RegulationTrafic
But that don't work, allways 0 pkts mached :
#sh policy-map interface Dialer0
Dialer0
  Service-policy output: RegulationTrafic
    Class-map: MatchRDP (match-all)
      3090 packets, 229558 bytes
      5 minute offered rate 2000 bps, drop rate 0 bps
      Match: ip dscp af41 (34)
      Queueing
        Output Queue: Conversation 267
        Bandwidth 5 (%)
        Bandwidth 38 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 0/0
        (depth/total drops/no-buffer drops) 0/0/0
Whhhhhhhhyyyyyy ?
Jerome
Silver
Re: Simple QoS problem
This does appear to be working.  The class map 'MatchRDP' is matching traffic as demonstrated by the 3090 packets in line 4 of the 'show policy-map interface dialer 0' output.
CBWFQ engages when there is congestion.  If there isn't any congestion the queuing counters at the bottom of the output will not increase.
Chris
Is your layer 2 encap ppp ?
Could you post a sh run of the interfaces and the complete dialer config ?
398
