Community Member
Simple Question About Connecting two SF200-24 Switches
I am assuming that this will be a basic quesiton but I have not dealt with more than one switch on a network before.
I am ordering two SF200-24 switches and need to connect them together. What is the best way to do this? Can i use both of the 1000 ports to tie them together or do i need to purchase the minigbic ports to accomplish that?
1 REPLY
You should be able to use the gig ports. Minigbic ports will be disabled when you use the other ports.
hth
MS
294
