Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SIP-400 and SPA-8XCHT1/E1 Compatibility, Are they compatible?
Dear all,
I have a problem. Currently I have 7609 with SIP-200 module installed and 2 SPA-8XCHT1/E1 sub modules on that SIP-200. I want to upgrade that SIP-200 to SIP-400 which provides more power. My question is, are they compatible. I dont have the hardware to test this compatibility. I have read SIP-400 datasheet. It says that the are compatible, but when I tried it on the dynamic configuration tool, when I choose SIP-400 as one of the module, it didnt offer SPA-8XCHT1/E1 as its sub module. This is what made me doubtful about the compatibility. So, if anyone has this configuration on their routers, please share... Thanks a lot guys.
Prima
1 REPLY
Hall of Fame Super Silver
Re: SIP-400 and SPA-8XCHT1/E1 Compatibility, Are they compatible
Hello Prima,
yes SPA 8 T1 channelized is supported see list of supported SPAs in
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9e6_ps708_Products_Data_Sheet.html
probably it is not supported on SIP 600
Hope to help
Giuseppe
304
