Site to Customer connection not working.
bradlesliect
I have been battling with this for days now. I have posted this question before but still no answer. I have a router at a customer site. This router is used to connect to my office network and back into the customer's network. Connection to my office network and Internet is fine. Connection to customer site does not work. The customer is able to connect to my router but to devices connected to my router. I inturn am not able to see anything on the customer side. I have re-created the scenario hoping to find a fix. Still nothing.nada.zip..... please help me with this.Its a 877 ADSL router. This is an extract from the config, hope it helps. I really need to fix this.
version 12.4
no service pad
service password-encryption
hostname brad-home-cr1
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
logging console errors
enable password <removed>
aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.18.44.1 172.18.44.128
ip dhcp pool brad-home
import all
network 172.18.44.0 255.255.255.0
domain-name home.brad.co.za
dns-server 172.18.18.65 172.18.16.65
default-router 172.18.44.1
netbios-name-server 172.18.18.65 172.18.16.65
ip domain name home.brad.co.za
ip name-server ISP PRI DNS
ip name-server ISP SEC DNS
username <removed> password <removed>
bridge irb
interface FastEthernet0
interface FastEthernet1
switchport access vlan 2
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description connected to other-inside
ip address 172.20.96.3 255.255.252.0
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Vlan2
no ip address
bridge-group 1
interface Dialer0
no ip address
interface BVI1
description home-brad-network
ip address 172.18.44.1 255.255.255.0
ip nat inside
ip route 172.20.96.0 255.255.252.0 172.20.96.1
ip route 172.20.96.0 255.255.252.0 VLAN 1
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source route-map SDM_RMAP_6 interface Vlan1 overload
ip radius source-interface BVI1
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
transport input telnet
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
5 Replies 5
bradlesliect
I have even added route statements to this. Still did not work. There is no access list applied to any of the interfaces or anywhere on the router. What next?
steveo123
You need to supply more info: what address block does the customer use ?? because there is no route back to the customer network as far as i can see from your config (static routing will need a route back if not running any dynamic routing). You have two equal metric routes for the 172.20.96.0 255.255.252.0 network, why is that there ? where is your default route to the internet ? unless the ISP routing is performed on 172.20.96.1.
In summary you will need to run a ISP provided VPN GRE/IPSEC tunnel over the internet (if customer site is remotly away) to the customer router inorder to estabilish IP connectivity then add static routes over that tunnel for ip routing. Please provide more info regarding the customer network and how the physical connectivity is estabilished.
Steve Knockswell
We are on the customer site. No routing to customer site should take place through the internet.
We connect to the customer's switch on Fe0 on this router. Fe0 has been added to Vlan1. I have heard of ppl mentioning that I should have a route back. The funny thing is that from the customer network I can ping the ADSL router but not anything on my network.
I don't think VPN connection is needed to cust network. The default route to ISP is not needed as we connect via ethernet cable to customer, hence the routing statement.
I see, well you are NAT'ing inbound from this router out to customer network 172.20.96.0 255.255.252.0. where is the route-map SDM_RMAP_6 ?? you need to specify that route map inorder to reach the customer network. You might want to try static one to one NAT statements to check connectivity.
Steve
Steve, I have taken what you said into consideration. Added the SDM_RMAP_6 but this still did not work.
Take a look at this config. The router has been split into 2 vlans. VLAN 1 is to the customer and VLAN2 to our onsite engineer. I can ping the IP on VLAN1 but can?t ping the notebook that I have connected to Fe0. What is wrong with this config? I?ve added a route map and access-list. The minute I apply access list 107 to VLAN1, I can?t ping the ptp on VLAN1. What?s missing?
version 12.4
no service pad
hostname
boot-start-marker
boot-end-marker
enable password
aaa new-model
aaa session-id common
resource policy
ip cef
ip dhcp pool pool-test
import all
domain-name domain.com
ip domain name home.domain.com
ip name-server 196.25.255.34 (ISP NAME SERVER 1)
ip name-server 196.25.255.3 (ISP NAME SERVER 2)
username password
bridge irb
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
no ip address
shutdown
station-role root
interface Vlan1
description connected to CUST NETWORK
ip nat outside
interface Vlan2
no ip address
bridge-group 1
interface Dialer0
no ip address
interface BVI1
description CONNECT TO MY NETWORK
ip nat inside
ip route 172.20.96.0 255.255.252.0 Vlan1
ip http server
access-list 107 remark IPSec Rule
access-list 107 permit ip 172.18.44.0 0.0.0.255 any
route-map SDM_RMAP_6 permit 1
match ip address 107
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
no inservice
end
