Site to Site VPN
Hi I am having the requirement with Site to Site VPN, I want to connect the vpn from bangalore to United states,in both both side iam having Cisco Pix firewall,how do you configure the site to site vpn in both side pix firewall?
Hall of Fame Super Blue
Re: Site to Site VPN
Cisco have a ton of good config docs for IPSEC site-to-site and remote access vpn's.
Here's a link to the page, specifically the pix to pix examples.
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html#anchor14
Have a read and come back if you have any more questions.
Jon
Silver
do u require ipsec or simple vpn.
if u need simple vpn then create gre tunnels mind one thing destination should be reachable and on firewall perform nat 0.
regards
shivlu
HI Ajay, [Do Rate all HELPFUL POSTS]
Please find the Attachment for VPN Configuration Samples and Command Structures.
PLS RATE if HELPS.
Best Regards,
Guru Prasad R
100
