SLA threshold
All,
I'm tracking a connection using echo with sla and then tracking that on my inside interface for hsrp to failover to my backup router. The problem that I've been noticing, is that when our primary router is under heavy load, the sla is failing and the router is failing over without a need to. Is there a way in sla that I can configure something like "ping 3 times in 15 sec. and then fail over if the host still hasn't responded after 15 seconds?"
This is what's in my logs:
Oct  8 10:07:39: %TRACKING-5-STATE: 1 rtr 1 reachability Up->Down
Oct  8 10:07:41: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 100 state Active -> Speak
Oct  8 10:07:51: %HSRP-5-STATECHANGE: GigabitEthernet0/0 Grp 100 state Speak -> Standby
Oct  8 10:08:34: %TRACKING-5-STATE: 1 rtr 1 reachability Down->Up
So, HSRP fails over immediately and then picks back up but I don't want it to unneccessarily flap like this.
John
HTH, John *** Please rate all useful posts ***
1 ACCEPTED SOLUTION
Re: SLA threshold
Try setting frequency to 5 (sec) and threshold to 15000 (ms)
This should make it so that you send every 5, and if the down state last for 15 seconds (meaning that none are successful in that interval) we will put it into a down state, triggering the track to change state, triggering the route to be removed.
hope this helps
Re: SLA threshold
hope this helps
Re: SLA threshold
I'll try that over the weekend....
Thanks!
John
668
