Slot Alarm on IGX8430
I am getting the slot alarm on UXM card.I checked dspslotalms , I can see only Minor Alarm on Slot.If I clear that Alaram clrcdstats , within one min. i again see Minor Alarm.What can I do for that.PLz suggest me.
Bronze
Re: Slot Alarm on IGX8430
you may try configuring the ubu to fix the minor alarm, take a look at the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/wanbu/bpx8600/9_1/91su/91sucmd.htm#xtocid17208
Hi!I Checked all, the config is:
FPkts/sec Cells/sec UBUs
Minimum Reqd Bandwidth: 12647 381 7
Average Used Bandwidth: 21404 374 11
Peak Used Bandwidth: 34985 3290 18
Maximum Port Bandwidth: - 28075 8
Allocated Bandwidth: 10
(Cell Only): - 40000
(Cell+Fpkt): 20000 30000
(Fpkts / 2 + Cells) <= 40000
Reserved Bandwidth: - 4000 1
Last Command: dspbusbw
109
